derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
Oct 21, 2022Guru - Experienced User
What FW is loaded on the router?
Would you post the first 3 characters of the serial number seen on the bottom sticker please.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
ghristov
Oct 21, 2022Tutor
FW version - 1.2.8.40
SN first 3 chars - 6K0
Before RAX120, I used the same LAN cable and ISP modem with Tri-Band Linksys 8300 router without any issues.
The problem was with those false DoS attacks caused by the camera. The same camera was working OK with my previous router mentioned above.
- FURRYe38Oct 21, 2022Guru - Experienced User
Thanks for the info.
- ghristovOct 21, 2022Tutor
ISP - The Bonds SAM WiFi Router, P/N SAM-4F1F-TT-W-A1.
- ghristovOct 22, 2022Tutor
Today I have started again my test with multiple 4K YouTube videos using several 802.11n, 802.11ac and 802.11ax devices working on 2.4 GHz or 5 GHz band in parallel. Everything was stable for many hours until ... I connected an old 2.4GHz 802.11b/g laptop playing YouTube video and the router restarted itself. It is not only my security camera which is causing restarts. It seems that all my devices that use 802.11 b/g standard for streaming are restarting the router. I have multiple security cameras and one laptop using 802.11 b/g. I have a streaming doorbell as well, but it use 2.4 GHz 802.11n standard and it is working pretty stable.
Conclusion: Every time in my tests when I use 802.11 b/g device for streaming the router restarts itself. If I use 802.11n/ac/ax device, regardless on 2.4 GHz or 5GHz band, the router is perfectly stable. Will continue with my observations ...
