derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
tr4sh80
Oct 31, 2022Apprentice
The latest beta firware finally fixes the issue. You can get it from DarrenM here or wait for the official to be released.
TheDude67
Nov 01, 2022Aspirant
Thanks buddy, I’m going to wait for the official release though. I bough this router because my older nighthawk was having issues and after researching it seemed this one was the best if the best. So far very disappointing with oerfmance and issues.
- tr4sh80Nov 01, 2022ApprenticeJust request the beta from DarrenM. It's been solid 2 weeks for me now and is finally the beast it was meant to be. Been a long time coming. Glad I was patient.
- mlm44Nov 01, 2022Star
The beta is working for me too. There is a glitch where the web interface shows the boot time for the CPU load and memory usage instead of percentages. I also noticed that there are no longer any DoS messages in the log (not sure if this was fixed or they broke something else). Otherwise the router is running solid, 4+ days without a reboot.
- tr4sh80Nov 02, 2022ApprenticeIt almost seemed like most of those DOS attacks where false positives because they were so constant....and it wouldn't surprise me if that was the core cause of the reboot issue. Routers tend to reboot after a certain # of dos attacks for security.
