derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
JMALEC75
Oct 30, 2022Tutor
Updated to the beta firmware. A little bit of a PITA with the static IPs I need, but was able to sort it out after a couple of reboots of both the router and the devices. Other than that, so far so good.
One thing I did notice was CPU Load and Memory Usage don't seem to work any longer. They show the date in the readout instead of the proper reading. Guess that's why it's still a beta, ehh?
Fingers crossed...
bgnome
Nov 02, 2022Tutor
I just noticed that CPU Load and Data Usage are being reported as Time and Date as well. Uptime is over 6 days so far..
- uhspcNov 04, 2022Aspirant
Hi guys
i recently bought one netgear rax120v2, and so i have same problem that your ....
reboot some times, one per days or multiple per days ...
i searched for troubleshooting, i disabled all my wifi components, and added one per one
i founded one old pc that use a wifi card realteck (asus rog g20) and disabled it
for unknown reason, is wifi connexion is inconstant and when i disabled it, wifi don't reboot all times (10 times on one hour)
BUT ... now another problem, rax120 reboot for another reason
firmware as been upgraded and rax120 has been reseted and reinit but rax 120 reboot some time per day
@DarrenM, can you give me beta firmware ?
- J7xNov 05, 2022AspirantWhen will the fix be officially released? Mine is just getting worse and worse. I’m going back to my old trusty Apple time capsule until this gets fixed.
- bobsbusiness84Nov 09, 2022Star
5 days on the beta firmware and it hasn't skipped a beat. It's great to see the real potential of this great router!
- tr4sh80Nov 09, 2022ApprenticeI'm on 18 days and change 🙂
It's looking very positive!
I'd love to know how they fixed it, but hope they can wrap it up into a full release for others quickly, it'll make life so much better for RAX120 owners who are having to suffer with the reboots.
