derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
uhspc
Nov 04, 2022Aspirant
Hi guys
i recently bought one netgear rax120v2, and so i have same problem that your ....
reboot some times, one per days or multiple per days ...
i searched for troubleshooting, i disabled all my wifi components, and added one per one
i founded one old pc that use a wifi card realteck (asus rog g20) and disabled it
for unknown reason, is wifi connexion is inconstant and when i disabled it, wifi don't reboot all times (10 times on one hour)
BUT ... now another problem, rax120 reboot for another reason
firmware as been upgraded and rax120 has been reseted and reinit but rax 120 reboot some time per day
@DarrenM, can you give me beta firmware ?
J7x
Nov 05, 2022Aspirant
When will the fix be officially released? Mine is just getting worse and worse. I’m going back to my old trusty Apple time capsule until this gets fixed.
