derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
Nov 14, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
verrnum wrote:
Hello,
I have the RAX120, and I'm facing random reboots also...can I have beta firmware please ?
Thank you
verrnum
Nov 14, 2022Aspirant
Hello,
The firmware version is : V1.2.8.40
the model numer is AX6000 WIFI Routeur RAX120
I use a CAT8 Lan cable between the Modem and the NETGEAR router,using the Multi Gig Port :
Regards
- FURRYe38Nov 14, 2022Guru - Experienced User
verrnum wrote:
Hello,
Regards
