derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
BaudNews
Nov 22, 2022Initiate
I've owned this router for 8 months now and have always had the random reboot issue through all the firmware versions. I sent a private message to DarrenM to request the beta/release candidate firmware and he graciously sent it to me last week for me to test and provide feedback.
Since applying the new firmware, I have nearly 5 days of continuous uptime without a single reboot. Before the update I was getting random reboots within 24 hours and never made it to 48 hours of continuous uptime. My router is located in a closet that stays warm (~90F ambient) and this heat is having zero impact on the router performance with no cooling accessories required. Everything is stock original including the power adapter and I'm even maximizing the throughput using a 5Gbps uplink.
I think the Netgear engineering team has really solved the issue with this firmware and hopefully they will be able to give it a GA release very soon if others are reporting the same successes without issues.
- FURRYe38Nov 22, 2022Guru - Experienced User
Glad it's working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-routerI recommend placing a USB Laptop cooler is recommended under the router. Keeps the router cooler and helps avoid heat damage over time.
Enjoy. 📡
- GMCbroMANNov 22, 2022AspirantSame issues, roughly same amount of time owned. And now I too have updated with Beta Firmware and 1st reboot was about 3 days after update, it was around 12pm which if that's the case doesn't truly affect me and I can definitely rest a little easier if it keeps it up. This seems to be the closest thing to a fix yet
Keep it up guys and I may just be able to stay on the NG Team.- FURRYe38Nov 22, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.What is the first 3 characters of the routers serial number please.
Did you factory reset the router and setup from scratch with out using any saved config backups from file?
Also change the default DHCP IP address pool range to .100 to .200.
Others have seen long past 3 days with out reboots. So you maybe seeing something else that's causing problems...Need to narrow it down more.
What devices do you have all connected?
How is Basic and Advanced Wireless settings configured?
Keep it up guys and I may just be able to stay on the NG Team.- blakey84Nov 22, 2022Guide16 days on beta and counting…
- Obsidian_Nov 23, 2022AspirantI need to get my hands on that firmware because mine is doing the exact same thing. I previously had the R7800 and it was perfect. It could easily handle all 60 of my connected devices without issue.
Needed to upgrade my router up at my cabin, so I bought this and boy has it been a mess. It's fast and puts out a strong 5Ghz signal but it gets overwhelmed all the time and the internet just starts chugging, dropping down to horrid speeds until it finally just lags out or reboots.
It's dropping all connections too, wired and wireless. I have a two APs in my house that are wired in and I use those for my 2.4Ghz smart home stuff, on separate SSIDs.
I turned off WMM and that helped a bit but still losing connection/rebooting 2 times a day. I finally just turned off the 2.4GHz all together but it didn't help.
Could you please point me in the direction of the beta firmware. I was mainly running Voxel's builds on my R7800 and now that all that's available for this is stock firmware I'm cringing at my purchase.- FURRYe38Nov 24, 2022Guru - Experienced User
What is the first 3 characters of your RAX120 serial number?
Could you please point me in the direction of the beta firmware. I was mainly running Voxel's builds on my R7800 and now that all that's available for this is stock firmware I'm cringing at my purchase.- Retired_MemberNov 25, 2022
Hi,
Please, can I test this beta fw?, I just bought a rax120v2 and also have this random reboot issue, I opened a case on 2022-11-16 and they never mentioned anything about a beta fw, or be of any help what so ever.
