derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
UnKnOwN-SiA
Jun 11, 2022Tutor
David22066
Nov 22, 2022Aspirant
I tried using a laptop cooling pad with a fan. It didn't stop the problem but it seems it speeds up the rebooting process so that the wifi is not down as long. But I still have my router rebooting several times a day.
- FURRYe38Nov 22, 2022Guru - Experienced User
What is the first 3 characters of your routers serial numbers please.
Did you get ahold of the beta FW file for this yet?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
