derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
Nov 29, 2022Guru - Experienced User
ebgp
Nov 29, 2022Tutor
Hi, I am having the same issue on RAX120v2, V1.2.8.40 (and previous releases). May I have a copy of the beta firmware to test please? First 3 of SN are 6JY - thanks
- FURRYe38Nov 29, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
- ebgpNov 29, 2022Tutor
TYVM. Connected to Arris SB6183 on xfinity service via cat6a. Will test with the beta firmware, appreciate it.
- FURRYe38Nov 30, 2022Guru - Experienced User
