derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
Adhit
Dec 02, 2022Aspirant
Hello been having the same problem. May I have the beta firmware as well please? My first three characters on my router is 6JY.
- FURRYe38Dec 02, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Adhit wrote:
Hello been having the same problem. May I have the beta firmware as well please? My first three characters on my router is 6JY. - cbinder4Dec 12, 2022Aspirant
I'd like to get the beta link as well. Same issue with the reboots.
RAX120v2 with serial beginning 6JY
Connected to Spectrum Cable via Arris TM1602
