derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
Splashngo
Dec 03, 2022Aspirant
im an IT network engineer, this wifi router is what is rebooting at least once a day if not 2 or 3 times a day. wired devices and wifi devices are losing connection. the fiber modem/gateway is staying alive during the netgear nighthawk's reboot.
Dec 03, 2022Guru - Experienced User
Let us know if you want to try the BETA FW that fixes the reboot issue seen on RAX120v2s
Please post the first 3 characters of the routers serial number on the sticker on your unit.
- SplashngoDec 05, 2022Aspirant
yes i'd like to try the beta firmware, first 3 letter is 6JY
- greggagDec 07, 2022AspirantHi. I have been dealing with this same issue for almost a year. I would like to try the beta FW. My serial number starts with 6JY. Thank You!
- FURRYe38Dec 08, 2022Guru - Experienced User
Sent.
greggag wrote:
Hi. I have been dealing with this same issue for almost a year. I would like to try the beta FW. My serial number starts with 6JY. Thank You!- DoNotBuyNETG3ARDec 03, 2022Aspirant
Long story short, I bought a RAX120v2 in June 2022 and the router would randomly shutoff and reboot. I've gone through pretty much all of their troubleshooting bullcrap and it still exists. Netgear seems to have failed to quality check their hardware before releasing it into the market and refuses to own up to it and make things right for customers who spent hundreds on this crap router. Not like it matters to anyone but I'm officially done with NETGEAR and moving on. you'd be angry too if you spent hundreds on a product and it's malfunctioning. Even the support team can't fix this stupid problem but I guess its the customers that screwed up for buying this crap product from NETGEAR.
