derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
Dec 03, 2022Guru - Experienced User
How about lets try loading up a Beta FW that has fixed this issue?
Please post the first 3 characters of the routers serial number seen on the sticker in back.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
DoNotBuyNETG3AR
Dec 03, 2022Aspirant
First 3 digits of serial number: 6JY
Firmware version: V1.2.8.40
I am serviced with Comcast/XFINITY
The modem I am using is CM1200 (a NETGEAR modem)
as for LAN cables, I am using CAT6
