derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
ebgp
Dec 08, 2022Tutor
Reporting back that since the factory reset and beta flash to V1.2.8.43-rc my RAX120v2 has been stable without issue. Uptime is 08:14:59:24 per debug.htm
31 attached devices.
This is looking promising, thank you.
Dec 08, 2022Guru - Experienced User
Thanks for letting us know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
- Ma3012Dec 08, 2022AspirantHi, I have the router router since 11.2022 and directly run into the reboot trouble FW is updated to the latest regular FW. Reboot occurs minimum note time on day, if there is some higher load on the wireless lan then the reboot can happen 3-4 times In one hour. May I can also try the Beta FW? SNR: 066
- FURRYe38Dec 08, 2022Guru - Experienced User
The SNR is the first 3 characters?
Ma3012 wrote:
Hi, I have the router router since 11.2022 and directly run into the reboot trouble FW is updated to the latest regular FW. Reboot occurs minimum note time on day, if there is some higher load on the wireless lan then the reboot can happen 3-4 times In one hour. May I can also try the Beta FW? SNR: 066 - Ma3012Dec 08, 2022AspirantThis are last three characters the first three are 6K0
Ok, Thank you.
Sent.
