derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
mlm44
Nov 29, 2022Star
A lot of troubleshooting going on here for what should be an inherently stable device.
My old NG router easily ran for six months at a time or longer on the same network configuration I have now.
The only change was the router. There is something about the RAX120 that isn't quite right.
But I will agree that it runs much better with the beta. 20 days and counting since the last reboot.
mlm44
Dec 08, 2022Star
About to reach my self-imposed 30 day uptime milestone on the beta.
- heat511Dec 10, 2022Aspirant
I am also having the random rebooting issue.
Can I get the beta version PM'd to me?
Serial starts with: 6JYARRIS SURFboard SB8200 using Cox Communications
- FlyingLordDec 10, 2022AspirantHello everybody.
I also have the rebooting problem with my Router.
My serial starts with 6K0. Is it possible to get the beta Firmeware as well? Or does anybody know when it will be a released?
Greetings - FURRYe38Dec 11, 2022Guru - Experienced User
Sent.
