derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
heat511
Dec 10, 2022Aspirant
I am also having the random rebooting issue.
Can I get the beta version PM'd to me?
Serial starts with: 6JY
ARRIS SURFboard SB8200 using Cox Communications
FlyingLord
Hello everybody.
I also have the rebooting problem with my Router.
My serial starts with 6K0. Is it possible to get the beta Firmeware as well? Or does anybody know when it will be a released?
Greetings
Greetings
- FURRYe38Dec 11, 2022Guru - Experienced User
Sent.
