derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
polemikus
Dec 12, 2022Aspirant
Thanks a lot. I'm starting to testing.
Did You saw it? Why there is no temperature information? Maybe that's the real problem?
Maybe the router just overheat?
Dec 12, 2022Guru - Experienced User
No that screen isn't officially supported.
And you'll not see additional DEBUG information on the debug page with this loaded, this is expected. Should be all corrected with next official FW release. This is only a patch for the random reboot issues seen on V2s. NG is aware.
