derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
DarrenM
Apr 04, 2022Sr. NETGEAR Moderator
I have PM you the firmware.
Tonynks
Dec 15, 2022Aspirant
Can I get the beta too please?
admin@tonystegall.net
- FURRYe38Dec 17, 2022Guru - Experienced User
Whats the 1st 3 characters of the routers serial number please.
What brand and model ISP modem is the NG router connected too please.
- ZerodameaonDec 17, 2022Aspirant
6JY, and for the modem its a Motorola MB8611 on Comcast Xfinity. Not sure if this helps but I am using the multigig port on the router since the service is over 1gb.
Be sure to use good quality LAN cable between the modem and router. CAT6A STP is recommended.
Sent.
Thanks, I have a Commscope Cat 6A F/UTP, that should be pretty decent right?
STP is recommended.
- TonynksDec 17, 2022AspirantDarrenM took care of me thanks for the help!
