derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
Dec 17, 2022Guru - Experienced User
Be sure to use good quality LAN cable between the modem and router. CAT6A STP is recommended.
Sent.
Zerodameaon wrote:
6JY, and for the modem its a Motorola MB8611 on Comcast Xfinity. Not sure if this helps but I am using the multigig port on the router since the service is over 1gb.
Zerodameaon
Dec 17, 2022Aspirant
Thanks, I have a Commscope Cat 6A F/UTP, that should be pretty decent right?
- FURRYe38Dec 17, 2022Guru - Experienced User
STP is recommended.
