derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
Dec 20, 2022Guru - Experienced User
Sent.
rax120v2 wrote:
I am also experiencing the random reboot issue every few days, with 2.4GHz radio disabled.
May I get the beta FW to test it out? Serial starts with 6JY on Spectrum model ET2251 DOCSIS 3.1 via CAT8 cable.
Itama
Dec 22, 2022Aspirant
I'd also like to request a copy of the beta firmware. Thanks!
Serial: 6JY...
Modem: Technicolor CGM4140COM
Provider: Comcast/Xfinity
- mvult2Dec 23, 2022Initiate
I have a NETGEAR Nighthawk WiFi 6 Router (RAX120) 12-Stream Dual-Band Gigabit Router, AX6000, purchased in April 2022. Serial starts with 6JY.
The WiFi completely goes down about once a day, for 1-2 minutes at a time. I've tried everything, including updating firmware, disabling guest network, and a factory reset.
Will the beta firmware help ? If so, please send it to me.
- no6969elDec 24, 2022Guide
Just got my router for Christmas and its doing what a lot are complaining about. Serial starts with 6JY. I am interested in the beta firmware. Manually rebooting fixes the issue. Leds on router show internet but all devices lose connectivity. Looking forward to testing this. Done everything that previous user stated as well.
Model: NETGEAR Nighthawk WiFi 6 Router (RAX120)
