derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
hfallife
Dec 26, 2022Aspirant
I got the same rebooting issue on rax120v2.
My serial starts with 6K0.
ISP: China Unicom
Modem: Huawei optixstar hn8346x6-c
Not sure if the beta FM fit for my devices. Thanks!
- no6969elDec 26, 2022Guide
I highly encourage anyone who is having these issues on their Knighthawk to please disable WMM (uncheck both) and test it out. This may work for you until they release a proper fix.
