derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
Jan 05, 2023Guru - Experienced User
Yes, I've got many reports back saying the beta fixes this issue on v2s. Working well.
Power adapters are not a factor in this either.
blakey84 wrote:
Everyone’s tried all of that. It’s a lot less hassle just to use the beta firmware…
Kips
Jan 05, 2023Aspirant
Got it. If that’s the best solution so far, can I get the beta firmware too?
SN starts with 6K0
Thanks!
SN starts with 6K0
Thanks!
- KipsJan 06, 2023Aspirant
What I got from ISP is Huawei HG8010H (fiber to ethernet) from which I get a public IPv4 assigned to RAX120v2 on WAN port with DHCP. Thanks!
- FURRYe38Jan 06, 2023Guru - Experienced User
Be sure your using good quality LAN cable between the ONT and router. CAT6A STP if your using the mutli gig port on the router.
