derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
freezer90
Jan 06, 2023Initiate
Been having reboot issues since the beginning of the year. Tried the other methods and haven't had much success. Would appreciate a link to the beta firmware that seems to be fixing the issue. Serial starts with 6JY.
Thanks in advance
- FURRYe38Jan 07, 2023Guru - Experienced User
What brand and model# ISP modem/ONT do you have the router connected too?
Sent.
Thanks in advance
- freezer90Jan 08, 2023Initiate
Connected to Verizon FIOS - Nokia G-211M-C
- betterfasterJan 09, 2023Guide
I have the same serial! Might be a bad batch?
