derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
kayvar
Jan 08, 2023Aspirant
Same problem. My Nighthawk AX12 AX6000 is rebooting every 30-60 minutes when we're actively using the internet. However, when we're heavily using it, the CPU still only gets to 5% load.
Nighthawk AX12 AX6000 12-Stream WiFi Router (RAX120v2)
Serial Number: 6JY...
Hardware Version: RAX120v2
Firmware Version: V1.2.8.40
CPU Load: 4.20792%
Memory Usage(Used/Total): 372MB/869MB
Flash Usage(Used/Total): 233MB/512MB
I even had my internet company come out and our line is great. Modem stays up the entire time.
It's been happening for about a week.
Can I request the beta firmware as well?...
- no6969elJan 08, 2023Guide
I don't think they are giving it out anymore. I believe they got the information they needed and now they are going to push it into an official update.
- FURRYe38Jan 09, 2023Guru - Experienced User
So was curious since you were given the beta...did this not work for you? Instructions were given to you on how to apply and setup the router for checking this. I've had many users tell me that this FW fixes the reboot issue. Sounds like you haven't tried the beta given or followed the instructions.
What's the brand and model# if the ISP modem that the NG router is connected too?
Sent.
kayvar wrote:
Same problem. My Nighthawk AX12 AX6000 is rebooting every 30-60 minutes when we're actively using the internet. However, when we're heavily using it, the CPU still only gets to 5% load.Nighthawk AX12 AX6000 12-Stream WiFi Router (RAX120v2)
Serial Number: 6JY...Hardware Version: RAX120v2
CPU Load: 4.20792%
Flash Usage(Used/Total): 233MB/512MBI even had my internet company come out and our line is great. Modem stays up the entire time.
kayvar- kayvarJan 09, 2023AspirantMy modem is
Motorola MB8611
My provider is Cox
No issues with my router until the new year
