derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
no6969el
Jan 08, 2023Guide
I don't think they are giving it out anymore. I believe they got the information they needed and now they are going to push it into an official update.
Jan 09, 2023Guru - Experienced User
So was curious since you were given the beta...did this not work for you? Instructions were given to you on how to apply and setup the router for checking this. I've had many users tell me that this FW fixes the reboot issue. Sounds like you haven't tried the beta given or followed the instructions.
