derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
kayvar
Jan 08, 2023Aspirant
Same problem. My Nighthawk AX12 AX6000 is rebooting every 30-60 minutes when we're actively using the internet. However, when we're heavily using it, the CPU still only gets to 5% load.
Nighthawk AX12 AX6000 12-Stream WiFi Router (RAX120v2)
Serial Number: 6JY...
Hardware Version: RAX120v2
Firmware Version: V1.2.8.40
CPU Load: 4.20792%
Memory Usage(Used/Total): 372MB/869MB
Flash Usage(Used/Total): 233MB/512MB
I even had my internet company come out and our line is great. Modem stays up the entire time.
It's been happening for about a week.
Can I request the beta firmware as well?...
Jan 09, 2023Guru - Experienced User
What's the brand and model# if the ISP modem that the NG router is connected too?
Sent.
Serial Number: 6JY...Hardware Version: RAX120v2
CPU Load: 4.20792%
kayvar
- kayvarJan 09, 2023AspirantMy modem is
Motorola MB8611
My provider is Cox
No issues with my router until the new year
