derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
RR_NG
Jan 08, 2023Aspirant
I would like to try the beta firmware as well.
S/N: 6JY
Modem: Motorola MB8611
ISP: Comcast Xfinity
Jan 09, 2023Guru - Experienced User
Please enable Private Message in our NG community profile preferences so we can send you the information regarding the beta FW.
S/N: 6JY
- RR_NGJan 09, 2023Aspirant
Private messager is enabled already under preferences. Is there a separate setting somewhere?
- seifrjdFeb 04, 2023Aspirant
Please also send me the info on the beta firmware to solve the reboot problem.
Thanks.
- chaosminionxFeb 05, 2023AspirantPlease send me the beta firmware for the reboot fix. I am on v1 and would like to test this based on positive feedback from offer v1 users.
- FURRYe38Feb 06, 2023Guru - Experienced User
Sorry, The beta is specific for v2 model routers.
Whats the first 3 characters of your routers serial number please.
Thanks.
- seifrjdFeb 06, 2023Aspirant
Info: RAX120-100NAS v2 Serial # 6JY21 ....
I have the v2 model ... please send me the firmware update.
Thank you.
