derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
Teknishun1
Jan 13, 2023Star
Over a year later and they haven't solved this issue. Way to go Netgear!
- FURRYe38Jan 13, 2023Guru - Experienced User
Is this with the recent beta?
- Teknishun1Jan 13, 2023Star
Why do we have to jump through hoops with a year old problem, put it into production, even if it's a checkbox.
What's the first 3 characters of your routers serial number please.
Let me know if you wanna give the beta a go. Everyone whos got it has reported it stopped the reboots.
