derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
EpicEnigma
Jan 13, 2023Guide
If you ask for the beta firmware, they will give it to you and it solved my problems completely. It needs rushed through beta and sent out to avoid all these headaches.
Teknishun1
Jan 13, 2023Star
Too late, I've boxed it up. I don't work for Netgear. They can send me a free one if they want to experiment on my time. Otherwise my consulting rate is 80/hr
