derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
Jan 16, 2023Guru - Experienced User
Whats the brand and model# modem/ONT the RAX is connected too?
Use the 1Gb WAN port or 2.5Gb multi-gig port for it's internet connection?
Sent.
GeneralKenobi wrote:
Could I get a link for the beta firmware? Having rebooting issues every couple of days. FURRYe38
Serial Number: 6K0
cookiemonsterr
Jan 18, 2023Aspirant
Can i please have the beta please
Serial Number 6JY, Modem Brand Sagemcom, Model# F@ST3896 UM, ISP Mediacom
- FURRYe38Jan 19, 2023Guru - Experienced User
Is the modem in router or bridged mode?
Sent.
- cookiemonsterrJan 20, 2023Aspirant
They have the WiFi turned off so I'm going to assume it's in bridge mode.
- FURRYe38Jan 20, 2023Guru - Experienced User
No, the router portion is still running. It's recommended to bridge the modem fully or use the DMZ on the modem.
