derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
Jan 23, 2023Guru - Experienced User
Please know that this FW IS From NG and the engineering team that worked to fix the reboot issue ONLY on the RAX120v2. User can only get this from here in the forums.
Some NG support group may not be aware of it and it won't be on NG support site for download. This is an internal FW patch for users with v2s only. It is sanctioned by NG and is only for the v2 and users seeing the reboot issue. Once NG engineering get this fully tuned in, NG will make it official and release it ON NG download site.
Thank you.
bachree
Jan 23, 2023Initiate
How do I request this beta firmware to cease the random restarts? Mine likes to restart at about 6pm every other day or so. I have confirmed that it is the router that is restarting and not the modem
I see that the official FW V1.2.8.40 was released in September 2022 and addressed security vulnerabilities. Is the beta FW older than that which makes the device vulnerable?
It is a V2 and Serial starts with #6JY225U
- FURRYe38Jan 23, 2023Guru - Experienced User
No.
Sent.
- bachreeFeb 06, 2023Initiate
I have applied this release candidate firmware 14 days ago and have not had a single restart. I was having 1 random restart a day on average prior to the update. I have followed the specific sequence that was requested.
- Update firmware
- Factory reset
- Fresh setup using hardwired computer through ethernet
- DHCP server IP ranged manual entered as 192.168.1.100 to 200
It is unacceptable to be going through this process for a 400 USD router that we happened to buy 5 of to have all business partners on same kind of equipment. Hopefully, Netgear does not break it again on a future firmware update.
