derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
Jan 23, 2023Guru - Experienced User
Sent.
RAX120V2_TX wrote:
Can i please get the beta firmware? I have the RX120V2 with S/N starting with 6JY.
Thanks!
RAX120V2_TX
Jan 23, 2023Aspirant
Its Spectrum one. Model ET2251
- FURRYe38Jan 23, 2023Guru - Experienced User
- no6969elJan 23, 2023Guide
Thank you for the response. So far Beta FW is working. Please push this to official asap as I think we should also know officially what exactly is going on. I want to know what needed to be changed to get this not to mess up, was anything downclocked or limited?
NG doesn't usually tell anyone how or what was fixed.
You'll need to keep an eye on NGs download site for the next official FW release is all I can offer.
Good Luck. - kreamerlolJan 25, 2023Aspirant
Hello, can I please get this beta firmware for my router too? Random reboots since I've owned it. Done the factory reset to no avail. RAX120v2.
- FURRYe38Jan 26, 2023Guru - Experienced User
What's the first 3 characters of the router serial number seen on your router?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
- kreamerlolJan 27, 2023Aspirant
The first 3 are 6JY for the serial.
I am using a Netgear Modem and high-quality CAT6 cabling too.
- FURRYe38Jan 27, 2023Guru - Experienced User
Is there a model# of the NG modem?
Sent.
