derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
Jan 23, 2023Guru - Experienced User
no6969el
Jan 23, 2023Guide
Thank you for the response. So far Beta FW is working. Please push this to official asap as I think we should also know officially what exactly is going on. I want to know what needed to be changed to get this not to mess up, was anything downclocked or limited?
- FURRYe38Jan 23, 2023Guru - Experienced User
NG doesn't usually tell anyone how or what was fixed.
You'll need to keep an eye on NGs download site for the next official FW release is all I can offer.
Good Luck. - kreamerlolJan 26, 2023Aspirant
Hello, can I please get this beta firmware for my router too? Random reboots since I've owned it. Done the factory reset to no avail. RAX120v2.
- FURRYe38Jan 26, 2023Guru - Experienced User
What's the first 3 characters of the router serial number seen on your router?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
- kreamerlolJan 28, 2023Aspirant
The first 3 are 6JY for the serial.
I am using a Netgear Modem and high-quality CAT6 cabling too.
- FURRYe38Jan 28, 2023Guru - Experienced User
Is there a model# of the NG modem?
Sent.
