derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
Ghbarker
Jan 27, 2023Aspirant
Can I get the beta FW? Serial # starts with 6JY.
Jan 27, 2023Guru - Experienced User
- cboghiuJan 31, 2023Aspirant
Please a beta firmware request rax120 serial 5F7
- FURRYe38Jan 31, 2023Guru - Experienced User
Sorry, that serial is for a v1 model router.
The beta is specific for v2 model routers.
- TrumpKingFeb 04, 2023Aspirant
After more than two months of testing on the beta firmware, I can confirm the beta firmware also solves my RAX120v1 issues (fw 1.2.8.40). My RAX120v1 (with fw 1.2.8.40) always becomes unstable or even loses Internet connection (both wired and wireless) due to overheat. It usually happens within in few days after a reboot.
The beta firmware makes the option "Always enable fan" work on routerlogin.com/debug.htm page. The fan never spins in current released version (fw 1.2.8.40). In the beta firmware, I also have to turn on the option "Always enable fan", otherwise, RAX120v1 still reboots every few days automatically.
My setup:
modem: CM2000
router: RAX120 (v1) with fw: 1.2.8.43-rc
ISP: COX
