derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
betterfaster
Jan 31, 2023Guide
I'm back to comment more after switching from Xfinity 200Mbps to Sonic 10Gbps.
Serial: 6JY
Hardware Version: RAX120v2
Firmware Version: V1.2.8.40
Xfinity 200Mbps + ARRIS SB6190 (using the Internet WAN ethernet port)
I ran NordVPN for about 1hour on my main PC pulling 2-3 Mbps. The router would reboot 5-10 times over 60 minutes, sometimes back to back reboots.
Sonic 10Gbps + Adtran SDX662v (using the Multi Gig 5G ethernet port)
I ran speedtests on speedtest.net and fast.com and noticed that fast.com causes the router to reboot about halfway through the upload test. Happens almost every time I run a test. I ran NordVPN for 30min or so pulling 2Mbps without issue. But up/down 400Mbps seems to guarantee a reboot.
- DarrenMMar 28, 2023Sr. NETGEAR Moderator
Here is a link to a beta firmware that has fixes for the reboot issue. Please let me know if you have any other issues with this firmware https://ntgr.my.salesforce.com/sfc/p/#300000000xsV/a/8b000000lpfE/ewZuT7whqirNo5U_QG.WfrQU.h0pa5dqpbB3qz_Qi3o
