derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
zdzisko
Feb 02, 2023Aspirant
Will you send this beta firmware so that netegar doesn't restart for me?
Feb 02, 2023Guru - Experienced User
I did. Check you inbox here in the forums.
- michaelkenwardFeb 02, 2023Guru - Experienced User
Reference to an "inbox here in the forums" is puzzling. It may, or may not, be a reference to a "private message".
Look at the top right hand corner of the browser window.
- Obsidian_Feb 03, 2023AspirantI've pmed you a couple times but could you please send it to me as well?
Modem is a Motorola MB8600
Router is a 120V2 Serial Number 6JY2.... - BaoMinhKhangFeb 03, 2023Aspirant
Pls help me!
- Giggi33Feb 04, 2023Aspirant
May I have the beta FW? My serial starts with 6K0. Encounter the same constantly rebooting issue.
