derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lesse...
- Jun 11, 2022Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
seifrjd
Feb 04, 2023Aspirant
Please also send me the info on the beta firmware to solve the reboot problem.
Thanks.
chaosminionx
Feb 05, 2023Aspirant
Please send me the beta firmware for the reboot fix. I am on v1 and would like to test this based on positive feedback from offer v1 users.
- FURRYe38Feb 06, 2023Guru - Experienced User
Sorry, The beta is specific for v2 model routers.
chaosminionx wrote:
Please send me the beta firmware for the reboot fix. I am on v1 and would like to test this based on positive feedback from offer v1 users.- seifrjdFeb 06, 2023Aspirant
I have the v2 model ... please send me the firmware update.
Info: RAX120-100NAS v2 Serial # 6JY21 ....
Thank you.
- chaosminionxFeb 06, 2023AspirantYou literally have v1 users reporting the beta solved their issues with instability and uptime/availability.
The firmware has been issued to v1 users. V1 and v2 have virtually nothing different about them besides a stepping change on the underlying processor.
How were v1 users able to get the RC firmware if it's only for V2?- FURRYe38Feb 06, 2023Guru - Experienced User
Only v2 users had reported seeing this issue. No v1s had been reported since this thread first started.
There was a initial test beta that same out about a year go that didn't work. This 2nd test beta came out last last year.
Why we are checking and conforming router serial numbers. Again, this patch is only for v2 since v1 hadn't been seeing this issue. There would be no need for v1 users.
