Deal
Jan 10, 2021Tutor
RAX120 vs RAX120v2: what's the difference?
I just purchased the RAX120 to replace an old reliable R8500 and was looking at the support information for the RAX120 when I found out there is an RAX120v2. Disappointed to find that since I just bo...
- Mar 24, 2021Updated chipset
Most distinct differences are support for...
1. UL OFDMA
2. TWT (Target Wake Time)
Other than that it shares the same Firmware base as RAX120.
Of course the RAX120v2 will supersede the RAX120 but if the above features aren't important to you then your RAX120 should be fine.
I still have my RAX120.
Newfiedrool
Jan 10, 2021Virtuoso
I believe the V2 uses the new version of the Qualcomm Hawkeye chip so it may support UL OFDMA this is then up to NG to implement.
I think February will be when you see the V2 but to be honest I can't say if you will see any difference, only time will tell.
QoS is what I would prefer to see sorted, it's not great as it stands sadly.
Topology
Jan 11, 2021Virtuoso
FYI: A data sheet describing the RAX120v2 is available, and the specifications appear to be the same as the original RAX120.
