Deal
Jan 10, 2021Tutor
RAX120 vs RAX120v2: what's the difference?
I just purchased the RAX120 to replace an old reliable R8500 and was looking at the support information for the RAX120 when I found out there is an RAX120v2. Disappointed to find that since I just bo...
- Mar 24, 2021Updated chipset
Most distinct differences are support for...
1. UL OFDMA
2. TWT (Target Wake Time)
Other than that it shares the same Firmware base as RAX120.
Of course the RAX120v2 will supersede the RAX120 but if the above features aren't important to you then your RAX120 should be fine.
I still have my RAX120.
vinniemac
Mar 24, 2021Luminary
Updated chipset
1. UL OFDMA
1. UL OFDMA
Topology
Mar 25, 2021Virtuoso
To clarify, are the UL OFDMA and TWT capabilities of the updated chipset actually operational in the the RAX120v2? Thank you.
- vinniemacMar 25, 2021Luminary
Sorry I do not know if the above 2 capabilities are Enabled out of the box on the RAX120v2, only that the chipset supports them.
I can however find out because it is important information for anyone looking to purchase just based on these features.
V1.2.0.16 is the latest Firmware for both units and if I recall this firmware was released before the release of the RAX120v2. That does not mean though that the firmware already enables these capabilities when the firmware is loaded on to the RAX120v2.
Cheers
- TopologyMar 26, 2021Virtuoso
vinniemac, FYI: The NETGEAR download center provides the identical firmware file (1.2.0.16), whether the router model is specified as RAX120 or RAX120v2. In addition, I see no reference to UL OFDMA and TWT in the product documentation for the RAX120v2.
Please share the results of your investigation into the question of whether these two capabilities are in fact operational on the RAX120v2. (Thank you.)
- vinniemacMar 26, 2021LuminaryRAX120 and RAX120v2 as I've mentioned share the same Firmware.
Engineering have mentioned its likely only UL OFDMA will be available out of the box.
The important thing is RAX120v2 does support both features. It's an updated chipset of course.
I cannot give any more information of when the features will be enabled, if they aren't already because I don't know this. I don't want to make any assumptions and give false consumer advice.
The thing with datasheets is if a feature is not available out of the box then it won't be listed but in case of RAX120v2 it's basically the RAX120 datasheet used.
Sorry I cannot be of more help to definitively answer your question.
