Deal's avatar
Deal
Tutor
Jan 10, 2021
RAX120 vs RAX120v2: what's the difference?
I just purchased the RAX120 to replace an old reliable R8500 and was looking at the support information for the RAX120 when I found out there is an RAX120v2. Disappointed to find that since I just bo...
  • vinniemac's avatar
    Mar 25, 2021
    Updated chipset
    Most distinct differences are support for...
    1. UL OFDMA
    2. TWT (Target Wake Time)
    Other than that it shares the same Firmware base as RAX120.
    Of course the RAX120v2 will supersede the RAX120 but if the above features aren't important to you then your RAX120 should be fine.
    I still have my RAX120.
