cjmiller1994
Aug 21, 2022Follower
RAX120 WAN Aggregation vs. MultiGig Port
I recently bought an RAX120 and CM1100 Modem. Both are capable of WAN aggregation. The RAX120 also has a MultiGig Port. My question - is the WAN aggregation typically better than using the M...
Aug 21, 2022Guru - Experienced User
Since the CM only supports 1Gb connection rated speeds. You might give LAG on the CM and RAX a try.
