Nighthaw-Newbie
May 30, 2019Aspirant
RAX120 WAN Port Aggregation To CM1200
Just did overhaul of whole home WiFi to CM1200 and three RAX120’s (1 as router and 2 as Wireless access points). Trying to do WAN port aggregation from modem to router then use multi-gig LAN to go th...
- Jun 06, 2019
Thank you everyone. Managed to get it fully set up today on WAN port aggregation. Should’ve known you guys would smoke Netgear Level 2 technical support. Thank you!
avtella
May 31, 2019Prodigy
The RAX120 can do WAN aggregation. It’s WAN+LAN1.
The support people you spoke to must not be knowledgeable. This isn’t the first feature aspect that they’ve lacked testing on unfortunately.
This is similar to some people who contacted support regarding HT160 support before it was added in an update and support told them it didn’t support it, I pointed out to some of those users that the unit was indeed FCC tested at HT160 and chipset capable of HT160.
avtella
May 31, 2019Prodigy
Go to “Internet Setup” page and select WAN Port aggregation after connecting WAN and LAN1. I should have clarified this earlier.
- schumakuJun 01, 2019Guru - Experienced User
Amazing, the 1.0.0.78 Release Notes (-> reference here) does talk of a feature fixed which was never introduced not documented, indeed:
- Fixes some web GUI page issues for the function of WAN aggregation port (Internet port + Ethernet port 1) or the Multi-Gig Ethernet port to be set as the WAN preference
- Nighthaw-NewbieJun 06, 2019Aspirant
