Nighthaw-Newbie
May 30, 2019Aspirant
RAX120 WAN Port Aggregation To CM1200
Just did overhaul of whole home WiFi to CM1200 and three RAX120’s (1 as router and 2 as Wireless access points). Trying to do WAN port aggregation from modem to router then use multi-gig LAN to go th...
- Jun 06, 2019
Thank you everyone. Managed to get it fully set up today on WAN port aggregation. Should’ve known you guys would smoke Netgear Level 2 technical support. Thank you!
schumaku
Jun 01, 2019Guru - Experienced User
Amazing, the 1.0.0.78 Release Notes (-> reference here) does talk of a feature fixed which was never introduced not documented, indeed:
- Fixes some web GUI page issues for the function of WAN aggregation port (Internet port + Ethernet port 1) or the Multi-Gig Ethernet port to be set as the WAN preference
Nighthaw-Newbie
Jun 06, 2019Aspirant
