HootieSC
Apr 03, 2020Follower
RAX120 Wi-Fi speed vs hardwired
Randomly, now a few times a week, all the wifi connected devices will come to a halt while hardwired see no disruption in service at all. My only option is to reboot the router and after about 4 min...
michaelkenward
Apr 04, 2020Guru - Experienced User
Your subject says "Wi-Fi speed vs hardwired". I assume that thi is not really the issue, but "dead wifi".
HootieSC wrote:
My only option is to reboot the router and after about 4 minutes everything comes back up full speed.
The only trick you have found, but what about checking to see what is really happening?
What do the LEDs on the thing show when this happens? WiFi ones still look OK?
Any prompts when you try to connect to the WiFi?
Any messages in the router's logs?
HootieSC wrote:
is this a shared experience?
If so, it should show up in a search of this bit of the community.
