koa132435
Oct 09, 2020Star
RAX120 WIFI Drops Signal (duplicated) when set for 160Mhz problems
I want to love this router but has some software or firmware problems. Router drops signal for at least ~3 dbm when configured for 160Mhz, this does not happen when configured for 80 MHz My setup L...
koa132435
Oct 09, 2020Star
One more thing with the 160 Mhz noted above. If I am too close to the Router. let's say 3ft the router never renogiate speed back to 2.4gbps even if I am got back to 12ft away from the router. I need to disconnect from the RAX120 AP and connect back.
- koa132435Oct 12, 2020Star
I got different router , AX88U, and I do not see the problem/behavior I experience with the RAX120. I actually see the opposite with the AX88U, signal increases when my laptop starts transmiting or receiving traffic. I have a sustained throughput with the AX88U of 850Mbps. With the RAX120 it varies 500-800Mbps even when the RAX120 has better signal levels :-(.
It seem this is Netgear related, maybe the way the implemented power related behavior or wmm. I really like the hardware specs of the RAX120 but it seems firmware is still not ready, sadly.
- Christian_ROct 16, 2020NETGEAR Employee Retired
Hi koa132435,
Thanks for your feedback regarding the RAX120. Please let us know if you still have the router and need further assistance.Christian
