coyote3
Dec 19, 2020Guide
RAX120 wifi drops until reboot
For a couple weeks the WiFi on my RAX120 has dropped a time or two a week; the ethernet connections were unaffected, and the WiFi returned after rebooting. This never happened before. The firmwa...
Dec 19, 2020Guru - Experienced User
I would try the factory reset. You can restore settings but if the issue persists, try it without using the backup. If its an old setting causing issues, the restore just adds the setting back in there.
You can also try downgrading the firmware.
- coyote3Dec 19, 2020Guide
Thank you very much, plemons, for equipping me with those smart suggestions!!
I'll report back on the resolution.
