AdeptMaven
Jan 13, 2022Guide
RAX120 with Google Fiber slow download
I recently switched from Xfinity's gigabit plan (1.2Gbs down/35Mbs up) to Google Fiber's bring your own router 1gig plan (~1Gbs down and up). For most of my time on Xfinity i had link agg setup so th...
AdeptMaven
Jan 19, 2022Guide
Hi Darren,
Yes QoS is disabled.
I'm on the latest Firmware. V1.2.3.28
DarrenM
Jan 19, 2022Sr. NETGEAR Moderator
Does the google fiber modem have a built in router? If so can you set it to modem only mode?
- AdeptMavenJan 19, 2022Guide
It's Fiber. There is no modem. There's a fiberjack with an ethernet port. My RAX120 is plugged directly into that port. My first thought was that heavy usuage during peek hours may be causing speed to suffer but using the speedtest on the Nighthawk app the router is consistently getting 920-940Mbs down and up. It's only the speed over wifi that seems to be sufferring. The speeds aren't totally terrible it's just frustrating because the speeds aren't as fast as I know they could and should be. The only thing I've changed is ISPs but the speed coming to the router would suggest that that is irrelevant.
- DarrenMJan 19, 2022Sr. NETGEAR Moderator
you could try a factory reset on the router maybe something is not right with the config since changing ISP connections.
DarrenM
- AdeptMavenJan 20, 2022Guide
I had to factory reset the router to switch to a new ISP, however I can try it again.
