rax12orrorbi
Mar 20, 2020Aspirant
RAX120 with iPhone 11 pro wifi 6 client. get half download speed 2-300 Mbps, but upload is 600 Mbps
I've been having issue with netgear model! I've bought the costco model RB840 Orbi. CC told me it's the device issue. So I bought the RAX 120 to see if it resolves my issue, but same issue! With ...
Topology
Mar 20, 2020Virtuoso
Rax12orrorbi, have you confirmed that AX is enabled in the router (see BASIC | Wireless | Enable AX)? Also, doing a power-off/power-on cycle of the iPhone may assist.
- rax12orrorbiMar 20, 2020AspirantYes! AX is on for both and I have cycled through...
- NewfiedroolMar 20, 2020Virtuoso
Have you performed a reset using the rear pin hole method after updating the firmware?
- rax12orrorbiMar 20, 2020AspirantYes! Went thru it with CS but that’s all they could do...
