rax12orrorbi
Mar 20, 2020Aspirant
RAX120 with iPhone 11 pro wifi 6 client. get half download speed 2-300 Mbps, but upload is 600 Mbps
I've been having issue with netgear model! I've bought the costco model RB840 Orbi. CC told me it's the device issue. So I bought the RAX 120 to see if it resolves my issue, but same issue! With ...
rax12orrorbi
Yes! AX is on for both and I have cycled through...
Newfiedrool
Mar 20, 2020Virtuoso
Have you performed a reset using the rear pin hole method after updating the firmware?
- rax12orrorbiMar 20, 2020AspirantYes! Went thru it with CS but that’s all they could do...
- NewfiedroolMar 20, 2020Virtuoso
Ok, I'm not familia with the modem and isp as I'm U.K. based.
Have you 2 separate WiFi channels or are you using one name setup?theres an app on the Apple store called WiFi Sweetspots. This shows your connection rate. Worth installing as you can see if there's an issue with router to device connection.
- rax12orrorbiMar 20, 2020AspirantYep done all of that and I’m still stuck with this issue. When I connect to other servers other than my ISP, I’m getting 5-600Mbps download (but not all servers).
Fast.com shows 2-300 Mbps. Google as well. So does the ISP speed test...beginning to think maybe it’s my iPhone
