Carlitto77
May 05, 2020Aspirant
RAX120 won’t connect to modem
My nighthawk rax120 has been an issue for quite a while now and between work and family stuff just haven’t gotten around to asking for support. It is currently unable to connect via Ethernet to my mod...
May 05, 2020Guru - Experienced User
You can manually update firmware.
What firmware are you on?
What modem is it connected to?
Carlitto77
I’m on firmware v 1.0.1.90 and the modem is an arris of some sort. My old nighthawk x8 is connected to it fine at the moment so I’m sure it’s not the Ethernet cable or the modem
- plemansMay 06, 2020Guru - Experienced User
Carlitto77 wrote:
I’m on firmware v 1.0.1.90 and the modem is an arris of some sort.------An arris of some sort? not even slightly helpful. My old nighthawk x8 is connected to it fine at the moment so I’m sure it’s not the Ethernet cable or the modemWhich arris?
Again, you can manually update the firmware. And the firmware your currently on isn't even on the previous firmware list. Meaning it was probably pulled for some reason or another.
so download the firmware, extract it, then follow the manual firmware install process and use the firmware you downloaded.
