whatsthepoint
Jun 16, 2019Guide
RAX120 WPA3 + WPA2 vs WPA2 Only setting
If I select the WPA3 + WPA2 setting my Surface Pro 5 tablet,HP chromebook and Pixel 3XL cell phone won't connect to my SSID. If I select the WPA2 Only setting all my devices connect? I know i...
avtella
Jun 16, 2019Prodigy
Yeah that is odd, I personally haven’t run into this issue with WPA2+3. Its doing fallback properly. My Intel AX200 devices are set to use WPA3 and the router is falling back to WPA2 for the rest, including all the Apple devices.
I assume the rest of your devices are working properly? I suppose if you file a case they can create an update to sort it out.
