Retired_Member
Sep 12, 2019rax120
very bad router, update rolled back 2 times, I warn you this is a very expensive router and no help from neggear
- Sep 13, 2019
Well you are posting in the community forums. Are you posting here for help (we are willing to help out) or just venting?
If you're posting for help more details will help us to help you.
What problems are you having? (the more details the better we can help)
what devices are having problems?
Modem your using?
Firmware you're on? Whenever you're changing firmware with these new devices, make sure to reset after you change firmwares. I'd agree that the firmware is pretty new and still kind of beta. The AX devices are still in draft form so its kind of the price that's paid for being on the cutting edge.
Sep 13, 2019Guru - Experienced User
Modem your using?
